Sorry about the size and two images but my scanner couldn't cut it as one.
At the risk of bragging there are several IMO clever bits in that design.
The FWR I was talking about is in middle of first image. That rectifier was -3dB @ 20kHz, at -50dBu (-3dB @ 10kHz at -60dB etc).
The current output of the rectifier feeds into a log convertor to provide a dB output. The voltage from the opamp used to generate the FWR also feeds a frequency counter.
Some perhaps interesting areas:
* frequency counter actually counts zero crossings so LF can be counted in 1/2 second.
*Log (dB) output compared to a zero dB reference and converted to frequency for + and - dB readout.
* simple voltage controlled osc runs over <20Hz to approx 30kHz range with <.2% THD (not trivial).
*note trick PS in top left corner. High current 5V rail unregulated is fed from switched rectifier to eliminate dissipation of dropping full unregulated supply. Pulled a lot of heat out of the unit and allowed operation from smaller transformer. Today this would probably be done with a switcher.
* sine wave output uses 51 ohm buildout resistor and is normalized to dB meter input so swept impedance measurements could be calculated from drop across the resistor (look up table was provided in accompanying book)
* frequency counter had div by 10 auto range. Nothing special about counter. Grabbed time base from mains frequency which was problematic for customers who did battery powered conversions.
While I apparently checked and signed off on that schematic I make no representations about the absolute accuracy, but it is a working design with thousands sold and in the field. I have one still working on my bench.
Trust me when I say there are many hours of design in that one schematic. Some of the things that may look like unneeded complexity are for first order temperature stabilization. Sine wave oscillator was not perfect over wide temp range but decent.
Biggest customer criticism of original design was desire for finer frequency adjustment. IMO that was more an artifact of having a frequency counter hanging off the output than really needed, but the customer is always right and a later version had a trim.
Enjoy
