[quote author="Rossi"]I don't know, I'm still with PRR's assessment. In the push-pull example you just posted, the signal reaches both bases at the same time. In the Oktava, the signal goes to the FET, configured as a source follower, and from there to the PNP emitter follower output stage.[/quote]
I'd say the signal (as fed thru the JFET and cap) reaches the PNP-base still fairly instantaneous for the frequencies at hand.
But which doesn't mean that I state that the Oktava is a push-pull as we know it :wink:
Let's forget about the labels, the discussion about the stuff actually happening in the circuits far more interesting.
Simple yet elegant zero gain circuit, if you ask me.
Sure, like it :thumb:
BTW. I did a sim with the 2N3819 and two different 2SK170 models (the ones from Linear systems, I can't seem to find an original Toshiba model). Bias points and (simulated) performance are almost identical. So one cool thing about this circuit is that it seems to be able to accept a great variety of components, which is probably a good thing for any Russian made mic.
I don't know how the model-parameters are set for those two devices. I saw I_DSS-ranges are about identical and the '170 has a much smaller VT-range. Perhaps the typ values are put close and setting them to their extremes might reveal larger differences. But maybe the two different SK170-parameter sets you threw at the simulator already were doing exactly that ?
One other thing I like about the circuit is that it doesn't require a zener. Probably a good thing for a small size mic. I recently found out that zeners can radiate quite some noise.
Yes, the dislike for Zeners because of that is universal.
Yet I'm wondering how noisy it still can be after filtering: when a zener is used you see it usually in combination with lot's of uF & some nFs in // to filter. Applications allowing it could also use a cap-multiplier.
The numerous mic-mod stories on the web
'and I got rid of the zener and I heard a better stereo separation in the upper bass-frequencies' are often not very well founded I'd say though, people associate zeners with noisy (they sure can be) and replace and unsurprisingly it's an improvement, you know how tests can be (note I'm NOT hinting that your experiments are among these).
So I expect that only a part of these mods would be a real improvement because of the zener-swap/mod when further scrutinized.
BTW, according to Motchenbacher the noise-mechanism for Zeners above ~5V is different
and 'worse' than for those below (<: Zener effect, >: avalanche breakdown & Zener effect, but avalanche dominant).
So use multiple stacked lower-voltage ones one would conclude from that. It'll increase BOM-cost, but replacing a ~12V zener with four ~3V ones is very feasible, at least for DIY.
Yet I'm wondering if it still all matters when adequate filtering is applied.
Regards,
Peter
