[quote author="hitchhiker"]how about Eddie's 470r on the voltage output as a fuse?[/quote] How about a fuse for a "fuse"? :green: Seriously, a fuse between the Q1 emitter and Q2/3 collectors would be my recommendation.
It sure is easier to buy a 25v transformer for this voltage doubler circuit.
So eliminate the bridge rectifier and use the V-doubler with an
18V trafo! It's DIY, baby! This is not so much meant to be a "cookbook" circuit, but a starting point. The max input should be about 55V. You want to pull about 5mA thru the zeners. So figure the resistor value by: (Vin-48)/5mA.
Not so much difference in this regulator circuit and the one that Ed uses. That circuit is going to send a lot of power out as heat as compared to that delivered to the load as he has ~70V at the input of the reg. With an 18V trafo and V-doubler, you'll get about 51V at the input of the reg. Some of the "12V" wallwart trafos will hit 18V with no load...that'll probably work fine for a couple of mics.
For one or two mikes (or a dozen typical 2mA mikes), you are trashing more heat in the R-Z network than in the pass element or the load.
Compromises everywhere, eh? As i said in the description this is a part of another bigger PS project not yet finalized...But I thought since I needed it in other projects that others would as well. On the prototype, I loaded it to 10mA with a 4.8k Ohm resistor and nothing on the PCB got very warm even.
Rafa, if you make PCBs, please make them double-sided...Then I'll buy some from you!
HTH!
Charlie
