SM PRO 8PRE Knobs
mikeyB
Manchester UK
Does anybody know a source for the knobs as used on the Pre 8 - they are plastic with satin aluminium finish and they have a 6mm "D" shaft fit. I can find solid aluminium types at RS in uk but man are they expensive! The ones used on the pre8 look fine. Check the links for pictures
http://www.smproaudio.com/index.php?option=com_content&task=view&id=34&Itemid=50
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=knob&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&resultsPP=100&Ntt=knob&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=4672429&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0679997569.1193414797@@@@&BV_EngineID=cccdaddmfmdhidicefeceeldgondhgj.0&cacheID=uknetscape
thanks in advance
Mikey,
It really helps us to make suggestions on where to buy that are relevant if you post your general location in your profile... I can suggest some places, but I doubt you are buying from the US.
If you live near Australia, you could probably get SMPro to sell you some.
HTH!
