NewYorkDave
As many of you know, small "transistor" type audio coupling transformers can sometimes be applied successfully as inductors in equalizer and filter circuits. Problem is, the inductances are almost never given, so you have to buy some samples and test them yourself to find the values you need.
I had a little free time last night, so I took inductance and resistance readings on several small audio transformers from Mouser. I figured this data could be useful to somebody. Please note that I did NOT measure distributed capacitance/self-resonance. Be sure to obtain and test samples of any type you intend to use before designing into a circuit. Fortunately, they're very cheap.
