I'm a bit surprised, given the background of many GroupDIY members, that more home DIY electrical work isn't done. I'n my county in California, owners can pull their own permits and do their own work, provided the work is 'after'/'downstream' of the main breaker. If it involves the utility company, then someone who is licensed and bonded has to do that work. When you pull the permit as an owner, it's inspected just like any other work, and the inspectors don't care who did it (although all of these rules vary from county to county and state to state), provided the person who did the work matches the permit (e.g. if a contractor pulls the permit, then they have to do the work. If the owner pulls it, then they have to do it).
Doing home electrical work carries all of the same precautions as working on tube musical equipment, so if you feel comfortable doing that, then electrical home wiring is vastly simpler. I think a lot of people are turned off by the complexity of the 2017 NEC codes, however 99% of the NEC is just definitions of terms, and stuff that has nothing to do with regular residential wiring. You can get a 6 page laminated set of NEC cheat sheets that cover everything needed to pass an inspection. The hardest part is understanding esoteric or seemingly arbitrary rules, like how often a cable has to be supported, and what types of wires can go in what kinds of conduit, what must be on a GFCI, etc). But the cheat sheets work in 99% of cases and are easy to follow.
