Welcome to out forum!
I will guess here, I'd need to have a real one with the 'others' you mention, which would be useful that you bring some examples, to look for and start a conversion from one to other and then see when they start to produce a similar signal.
Neve is a really good designer, and it's about design the differences between one circuit and other, rather than topology, of course topology is an important fact in the response of a piece of equipment. But when designing something you have to pick every single value and type of components, devices to use, etc. And here is where the compromise happens. I think he picked really careful not only the topology but al the variables together and that's what makes the difference, then is a matter of taste, from the designer and end user, how will respond and what sounds better where respectively. Neves designs, not only 1073, has really good critiques compared with other designs with a similar topology, you can go for some AB type consoles, or even mass production ones, and all will have something interesting. Take the focusrite, or some amok as example. Other designers also has their own signature, Saul Walker designed the eq you know around 1970 and still in production by API with slight changes, they incorporate jensen transformers when it came out, when switches used no longer available they asked custom made switches and take this opportunity to add some freq to the bands, etc. but the design is just the same. Saul also worked in other companies but not too much work on audio signal path but more on automation or broadcasting/movie mixers. But we still like the Quad8 eq where he has involved for example. A lot to learn from gurus like them, study their schematics in a critical way and understand those completely is a good way to start, try to make assumptions why did they take those choices is a good exercise, guess why the difference between one design and other I'm not sure is a good practice, doing a good and clever comparison may be good though.
JS
