sahib
The 500 rack was a pre-production sample. It did not have the rear panel. However, I also had a left over 51x-511 rear panel which is slightly shorter in length and the screw holes onto the side panels do not match. There are also a few screw holes that are not used as these go over where the notches were cut on the flange for SubD25 connectors. I pointed these out in red.
But as the rest of the screws perfectly in place the rack holds rock solid. The power connector hole accepts both 5 and 7 pin Neutrik. The top/bottom/side panels and rack ears are unpainted. The rear panel is powder coated in matt black. The 5 x little holes on the right hand side is for status LEDs.
No backplane PCB is included.
The psu case is made of aluminium. There are 6 fuse holder and LED holes and two cable glands holes for two cable output on the front panel. The rear panel has the holes for IEC and mains selector switch. I will supply the Rapid order codes for the IEC, fuse holders etc. No PCBs are included but if required I would happily supply blank boards and transformer separately.
GBP 50.00 for the lot. Plus shipping and paypal.
