Update on metal work.
The faceplate design I posted a bit back works like a charm, and overall dimensions seem to be lining up well. Here's the new faceplate next to the old, which you can see my roughly-accurate ruler printouts I used for measuring the fader scale. (resizing the image did hell on the channel separation lines... they look better than that )
A closer look of the overall structure, from the top. Corners seem to line up well.
Side View:
Switch PCB's:
On top of the fader plate, I'm going to have a 6" tall "holding faceplate" with just the pan controls for each channel. The 6" should allow enough room for plenty of future expansion... a couple auxes, cues, maybe a couple extra busses, mute/solo, polarity, hell, maybe even a hpf. On top of all this will then be the CAPI 508 double bucket with eq in lower, mic pre in upper, then space for a meter bridge.
That's where I'm at now. More to come. Thanks for looking.
Keith
Side View:
Switch PCB's:
Keith
