[quote author="radiance"]@Flatpicker: I thought of puting those Haufe trannies behind the discrete opamp part. Anyway, maybe I just try both options (with and without the discrete opamp..)[/quote]?? If you put them behind (before?) the discrete amp, you won't have a balanced/differential output. By the way, it's not an op amp, just a multi-stage DC coupled amp. Personally I'd forget it and just use the Haufe trannies since you?ve got them. You will more than likely be feeding a much higher impedance than 600 ohms. Besides, it'll simplify your power supply.
