There are two papers discussing the M50 capsule.
http://recordinghacks.com/pdf/neumann/omni_sphere_aes_schneider.pdf
I would like to know where that myth about the 0.8 Micron comes from... I've read it a few times over at Klaus Heynes Forum. There some also mention a Nickel M50 capsule.
There is no mention in any "official" documents that states that the M50 was ever made with a Nickel diaphragm... It's only PVC, ALU and PET Gold. So the mentioned "metal diaphragm" in the Neumann paper has to be the Alu one.
I don't even know, if it is possible to tension a 0.8 Micron Alu foil to that extend...
As I experimented on a tunable omni capsule with different thicknes of membranes I'm lead to believe that the actual thickness is not a deal breaker. I would say it's one of the least "problems" to worry about if you stay inside a certain area (2-12 micron).
I don't say the thickness doesn't effect anything but the effect is rather small compared to alot of other things that make a capsule a great capsule.
EDIT: just read that the K33 of the TLM50 was made of Nickel. But as the other paper states they used a 2.25 Micron diaphragm in the TLM50.
