oh.. ok, I asked for FedexI use fedex. It's usually pretty cheap but you have to pay whatever the import tax is when you receive it
Yeah, I just saw that, sorryView attachment 146038you didn't
That's my thought. We did do CNC as opposed to hot punching it like Neumann did and plus, it's not actually Machining grade Bakelite either. well, this is why we do tests.Maybe residual stress from when it was manufactured?
All my life I hated Bakelite. It is an unstable material in terms of mechanical, thermal, chemical resistance, it becomes fragile, brittle, sometimes it loses its dielectric properties. It was a nightmare for electronics. For decades it was used in electrotechnics, electronics, in the former Eastern European communist bloc. And now I have unpleasant memories of the Soviet components, parts, which contained Bakelite. The same situation in the field of household appliances or industrial uses.That's my thought. We did do CNC as opposed to hot punching it like Neumann did and plus, it's not actually Machining grade Bakelite either. well, this is why we do tests.
To obtain a very high quality of the surface of the holes, you must resort to more demanding technologies (rectification, honing, lapping, polishing). These mechanical processes require special equipment, tools, consumables, technologies, high precision, a special qualification of the workers and an impeccable technological discipline.I found that the inside of the holes on the early Neumann back plates was very smooth, and some of the holes had a platform at the bottom. Those platforms should have been specially designed that way and were processed in several times to ensure that the inner wall was smooth and consistent. The internal smoothness of the hole and the size of the hole should have an impact on the reflection of sound waves. In many replicas, the inside of the hole is very rough. If you use modern CNC, it should be possible, but it is not very easy to maintain consistency, and the cost is also high.
I think they must have a role. These holes are hidden behind the diaphragm, and the inside of the holes cannot be seen from the outside. As a manufacturer, in terms of processing costs, they should not waste these unnecessary work. As far as I know, the position and depth of the holes on the back plate have an impact on the frequency response.I would be curious to hear what the effects of this polishing of the holes are in practice.
Hi @paulster44 !How to order?
This is Soliloqueen capsules?Hi @paulster44 !
If you want to order Arienne capsules:
https://store.arienneaudio.com/13-microphone-capsules
The effect of the "protective hat" above the capsule is acoustically minor.Can't you do some measurements with pink noise?I think it's worth mentioning, Ari's capsules are being delivered not only with a decent capsule holder, but also including a little "roof" to protect the capsule from hitting the head basket in case of an accident.
As I wanted to mount my K87 as high up in the head basket as possible, I was really happy to find that roofy inside the zip bag.
@soliloqueen Does this thing also have an audible/measurable effect?
