[SOLVED]Motor transistors keep dying on me
@RoadrunnerOZ yes, those are always active.
Swapped the dual cap plus diodes – no difference, supply transistor died this time. It seems to select its victim randomly
Yes, this sounds reasonable. I'll see if I can dig out some caps in the studio. Got way too much stuff
With the two transistors removed from the circuit, what sort of voltage levels do you see at the base connection on the transistor sockets as you move through the various modes?
FFWD: around 11v on take up, 4von supply
RWD: opposite
PLAY: 3v on supply, 6v on take up
I am not sure if the actual voltage levels are correct, but those proportions seem logical to me as they relate to the torques being applied to the motors for the various modes.
Does the calibration manual provide any info about these levels?
I was almost going to say "no", but I remember seeing these levels stated in the manual somewhere, so yes!
And with the transistors removed what do you measure from the collector connection on the transistor socket to the emitter connection on the transistor sockets in the various modes? (I assume these will be independent of the modes)
It's weird as hell, I measure a bit past 400 DC at idle, and when I press rewind it goes down 10 volts or so, and when I press fast forward it jumps up around 10 volts (from idle, measured att supply motor collector-emitter). These values are perplexing to say the least
Disregard my previous message (I guess??) It's still sitting at 400VDC at idle and jumps up to 450 in ANY mode now. Measured between collector and emitter
Unplug the supply motor, and do the same measurements across the collector to emitter connections on the sockets, then repeat with the take up motor removed
