Some fantastic eagle tutorials
Ptownkid
Ajax, Ontario, Canada
This one is on schematics
http://www.instructables.com/id/EXU9BO166NEQHO8XFU?ALLSTEPS
and this one is on board layout
http://www.instructables.com/id/EZ3WN1QUKYES9J5X48?ALLSTEPS
custom library parts
http://www.instructables.com/id/ERHQQ180Y3EP286NQY?ALLSTEPS
and modifying design rules
http://www.instructables.com/id/EZVIGHUBGCEP287BJB?ALLSTEPS
enjoy
[quote author="Ptownkid"]This one is on schematics
enjoy[/quote]
Yes!!!
I was going to post these when I got Eagle installed on my MacBook. I wanted to try them first, but the looked great!!
This should defintily go right to the meta....
I bought the stripped down standard version (no auto-router) so I can work on bigger boards. I guess I could use a different computer with the demo license, but so far I've just manually drawn traces, it's kinda like a puzzle. I put a lot of thought into component placement.
here's a question.... obviously i could create the part, but i can't seem to find a standard pcb mount toggle/pushbutton, like is used on fabios 312 boards, or jlm switch boards, or whatever.. they're all over the place. i figured i could find one online somewhere, but its a no go so far.
any body have anything along those lines?
[quote author="Ptownkid"]Which one is the stripped down version that allows larger boards? [/quote]
EAGLE Standard (Limitations: 4 signal layers, 160x100mm routing area)
1-User
Layout-Editor (basic program) US$ 199.-
Schematic-Editor module + US$ 199.-
Autorouter module + US$ 199.-
I just didn't buy the auto router module.
[quote author="enthalpystudios"]here's a question.... obviously i could create the part, but i can't seem to find a standard pcb mount toggle/pushbutton, like is used on fabios 312 boards, or jlm switch boards, or whatever.. they're all over the place. i figured i could find one online somewhere, but its a no go so far.
any body have anything along those lines?[/quote]
here's a good pushbutton, but it's not panel mount
Digi-key - F2UEE
te]
Oh wow, I never noticed that before, so the "full" standard version is 600usd and the full "full" version is 1200usd
Daaaaaaaaaamn
So what is the Schematic-Editor module? You can't draw schematics without it?
It's just the schematic page. Without it eagle would be pretty boring (you could use the packages, but not the devices or symbols) and you would have to route everything without the help of a schematic. Pretty much impossible.
[quote author="handcrafted tone"]use the CAM presets. In the board view, click on Cam Processor button. When the window opens, click File->Open->Job. These are presets that are saved in your eagle program CAM folder.
Choose excelleron and generate the drill data.
do file->open->job again and choose gerb274X. This generates the gerber.
Some manufactures will automatically mirror the bottom layers, if this is the case un-check the "mirror" button on bottom layers when generating the gerber.[/quote]
check this thread
http://www.groupdiy.com/index.php?topic=19381&highlight=eagle+cam
At least on Windows XP eagle is perfectly happy with multiple installations using different licence keys. The only catch is that they will both share directories for lbr/projects etc, which is a good thing IMO.
