Some Quick Mic Pre Input Transformer Questions
[quote author="CJ"]A realization, if one leg is pulling more than the other, it does not matter if it's thru the CT or not, you will still have a voltage difference across the windings.[/quote]
You're right. This would cause at least some of the "extra" current to be pulled through the transformer primary from the other side's 6k8 resistor.
