Hey everyone, hopefully this is the right place to post this. I've been reading the board for several years now trying to absorb as much info as possible withought trying to bug the users with random, but haven't really had anything to add, just here to absorb the knowledge of the members here.
Anyway I recently acquired a Soundtracs 16-8-16 board. While everything seems to work just fine with the exception of a few latching switches that are stuck, so I can't select mic/line levels on few channels. The board has a slight noise in all chanels so it's likely time for a recap.
My main problem stems from the Sountracs Universal PSU. It's evident someone at some point did some repairs(to D12) on the unit that I don't understant. I will attach a page from the document from Tim, but will take it down asap if Tim has a problem with his docs being posted.
Anyway, for some reasons somesones fix was to afix what I assume a zener diode in series with another diode in what I imagine is the phantom supply section. It all still works, but I don't feel comfortable leaving that there when a proper diode could be afixed in place.
I will attach a picture of the area with the odd diode configuration and well as Tim's doc.(Again if Tim has a problem or another member see that I should remove it, I will do so asap).
I forgot to metion that the offending diode is D12. I had talked to my brother who was an EE in a previous life time and he suggested jst replacing both with a standard diode. I have several LN4005 diodes in stock but likely have some more values in my parts bin.
All help and suggestions will be greatly apprecieted
Graham
Graham
