deveng
I need some information and advice. I've been playing guitar through vintage Fender amps (6v6 and 6L6) for many years. My 1955 Deluxe and 1962 Bandmaster sound very good and they have a signature sound. I designed and built a tube preamp stage with a Marshall tone stack and it does add some flexibility but they still sound Fenders (no surprise). I do both recording and performance and have been looking at some of the boutique amps to get an additional sound that I've not been able to get from the Fenders. Interestingly, I've found that amps with EL34 or EL84 output tubes are the ones I like.
I just happened to have an old Altec 345A amplifier my father gave me! It's a 60W stereo amp that uses EL34 output tubes, Peerless transformers and it works. One channel has a pair of old Amperex EL34's. As an experiment I ran my guitar through my tube preamp (which has both line level effects loop and a high impedance output to guitar amp) line output into the Altec. To my pleasant surprise the tone was there.
Has anyone here modified an old tube amplifier like this to use as a guitar amplifier? I'm thinking about keeping the Altec generally intact and adding additional preamp gain stages (externally) using one channel as a "clean" and the other with more gain to push the EL34's. I don't have a schematic yet. It uses a 6AU6 and a 6C4 with each pair of EL34's. It also has a 5U4GB rectifier. The amp is fairly quiet but suspect it could use new filter caps (Mallory FP 40uf 500V) and will likely need new coupling caps.
Before I take on this beast, do you think it's worth the effort? I figure for a couple hundred I may have the makings of a very good recording amp.
Any comments?
Regards,
Jeff
Any comments?
Regards,
Jeff
