I would like to see distortion plots for these suspect pot media. In my experience pots were not significant sources of nonlinearity.
I keep hearing this claim on multiple forums but have yet to see a citation.Does carbon really do that ? Not aware although tbf I was only involved in working with CP pots / faders.
Any figures / results as to the magnitude of the harmonic(s).
Yes !
In hindsight I have encountered some misbehavior from dirty wiper contacts inside unsealed pots, over the decades.From my time at P&G last century - I can say that distortion / non-linearities were never debated or the cause of customer comment IIRC. Mostly faders, some rotary pots. All CP. Lots of other issues addressed - "Cut Off" ; lubrication ; oil migration ; cross-talk ; screening ; wear characteristics. But not distortion.
In terms of signal path a major point was the conductive epoxy used to connect wires to the track(s). In relation to impairing "Cut Off".
Like the stuff used to repair car rear screen heaters that often doesn't work because it's too dried out.
The stuff was mixed in house on a shaker table using silver loaded epoxy IIRC and had to be used that shift.
The problem I had with P&G RF15's was significant and widely varying series resistance at the end of the throw. If the pot is buffered it's not a big deal but becomes a big deal if used as an output fader with no buffering.Lots of other issues addressed - "Cut Off" ; lubrication ; oil migration ; cross-talk ; screening ; wear characteristics.
I wouldn't say that's true, especially in an older open pot. There are millions of noisy receiver controls in consumer equipment. Wipers and resistance elements wear and oxidize, especially in unsealed pots creating little diode contacts which are non linear with voltage and don't need to be turned to cause havoc.they can only make noise when you are moving them...
your optionI wouldn't say that's true,
? noisy with no signal when not being moved...?especially in an older open pot. There are millions of noisy receiver controls in consumer equipment.
I have never seen that with the exception of crud on wiper fingers, as I already shared..Wipers and resistance elements wear and oxidize, especially in unsealed pots creating little diode contacts which are non linear with voltage and don't need to be turned to cause havoc.
In my decades in the trenches my experience is that pot resistive elements are far from the weakest link and not a significant source of audible distortion. Of course opinions vary (apparently).I'm not an expert on what's the best material so anyone who needs to know has to do their own research, but suggestions would be welcome, I'm sure.
are you sure it was oxide? I have seen some gear pulled out of smoky clubs that had a layer of crud on everything inside.I have seen a handfull of pots where a tough layer of oxide formed on the wiper , more or less cut signal off entirely , needed to be scraped away
your option
Indeed.
Only when turned off.
Give it time. It's early.
In my trench I used to fix receivers and TVs for a living as a "yout'". Yes, signal distorted or open missing signal in some positions. If there was DC on the pot - grid, gate or base current through the wiper can cause noise. Resistors get noisy, why not pots? And the metal ring the other end of the wiper rides on can get crunchy, too. Oxidation, salty sea air, city pollution.
I can measure distortion that I can not hear... I never heard distortion that I could not measure but back in the 70s I rolled my own two-tone IMD analyzer to better parse out HF non linearity that wasn't well revealed by typical THD+N measures (any active circuit with a LPF would roll off the higher distortion products too).I guess it depends on how your perceive distortion.
I fixed stuff for free...(as a kid), when older I designed stuff for a living.In my trench I used to fix receivers and TVs for a living as a "yout'".
yes I've seen my share of faulty pots, but not many new ones, bad because of "what" they are made from (while I have seen some new ones fabricated incorrectly).Yes, signal distorted or open missing signal in some positions.
and don't forget leaky or backwards electrolytic caps..If there was DC on the pot - grid, gate or base current through the wiper can cause noise.
I don't know about resistors "getting" noisy, while even new resistors start out with several kinds of noise (Johnson noise, excess noise, etc.)Resistors get noisy, why not pots?
glad I never had to deal with marine repairs. Salt water sux... just ask those Tesla owners who got flooded in FL The salt water turns their car batteries into time bombs.And the metal ring the other end of the wiper rides on can get crunchy, too. Oxidation, salty sea air, city pollution.
that makes for thousands of potential problems in a console. I experienced lots of problems with insert jack switch contacts, They could get oxidized and intermittent if not plated properly by the manufacturer (cough... Switchcraft).Anywhere there's a contact there's a problem waiting to happen, IMHE. Including solder joints.
we all rock a different path... but the same laws of physics apply to all of us. We all can learn from each other.That said, your mileage varied from mine and thanks for posting your experience.
Mr. Moscode
Good ideaJohn Roberts and I are on the same page re. null testing. Can anyone find a long length pair of rusty barbed wire, wrap it in duct tape, and null test it with a similar length of Mogami/whatever cable??
Bri
It's important to distinguish between noise, that happens mainly because of a malfunction (dirt, worn track or wiper), and distortion, which is the original question.I wouldn't say that's true, especially in an older open pot. There are millions of noisy receiver controls in consumer equipment. Wipers and resistance elements wear and oxidize, especially in unsealed pots creating little diode contacts which are non linear with voltage and don't need to be turned to cause havoc.
I can also tell you that trying to make a record with scratchy pots and iffy switches is a real drag, and that probably more pots & switches go bad from lack of use then over use
As to how different pot track materials sound, that's deeper than my knowledge. I am pretty happy if they work cleanly and consistently over time. A long time!
Audio electronics is actually pretty mature technology. Wire has been pretty well investigated with hyperbolic claims debunked. Back in the 1980s I used to write a column in Recording engineer/Producer magazine called "Audio Mythology". Funny speaker wire was one of my column topics and IIRC I cited AES papers (Griener?) and more.I can find samples of all the crappy wire ever use from the beginning of audio gear!
I just don't have time to play with it... I could probably send an assortment to someone if they do.
I can tell you that hit records were made on all the gear that had this stuff inside, (and on ADATS and Pro Tools MIX systems, too! Who knew) and I can also tell you that trying to make a record with scratchy pots and iffy switches is a real drag, and that probably more pots & switches go bad from lack of use then over use ...
