Spiritworks
I am looking forward to a pair of theseCOMING SOON: AB528 Microphone preamp
(more details at the start of this thread)
No no no. That's an ugly fix. What tools do you have for unsoldering things? That should be an easy one since only every other hole is soldered and the PCB is single sided.So I’m assembling the MP573 - and should’ve went to bed, but kept working and unfortunately made a small mistake on backside PCB of the input transformer and soldered the pins on backwards. I’ve tried to unsolder it for about 20 minutes and I’m a bit concerned I won’t be able to fix my mistake. If need be, can I just superglue the PCB to the transformer and call it a day, or will there be too much heat?
My understanding from looking at it is that it’s only there to support the weight of the transformer correct?
Adam
Unsoldering braid. It works fine for normal components but when all of the holes are attached at the same time it’s tough to pull up the component while the solder is hot haha.No no no. That's an ugly fix. What tools do you have for unsoldering things? That should be an easy one since only every other hole is soldered and the PCB is single sided.
