Soundcraft Spirit Live (1990) mic input gain reduction mod
mihaelbele
Member
Zagreb, Croatia
It seems that mic preamps have +10db gain when the gain pot is in it's zero position. Is there a mod to reduce gain to unity at pot zero position? Or even implement as trim/gain function? I think that the mod would affect the line input gain too, so I would probably leave few pairs of inputs as they were.
I'm mostly using electrets, and can only resort to resistive pads if mic capsule has a built in FET, but even the AKD D112 gets clipped when used in bass drum.
I've found a channel schematic this thread: link
Try reducing the values of R17 and R18. To drop the gain 10 dB you want to reduce the 12k to 1/3 or roughly 4k.
Maybe only modify one channel first to see how it works, before doing more.
Couldn't you also increase the value of R16? That looks like the classic instrumentation amp front end where decreasing resistance increases gain, and R16 sets the minimum resistance when the pot is all the way at one end. Changing R16 has the benefit that you don't have to worry about matching the replacement resistors (although for that class of device they may not be matched super closely to start with).
No.. R16 establishes the maximum gain not minimum gain (OP's complaint). You would need to replace the 5k gain pot with a larger value which also involves an unusual non-linear taper making them even harder to source.
It's commonly known as a "Cohen" topology.
minimum resistance commands maximum gain...
I would recommend using 1% resistors for R17 and R18, I didn't suggest a specific value because I don't remember them all. Should not be hard to find.
Thanks guys!!!!
I'll try it over the weekend and let you know :)
It works! Tested with linkwitz modded WM55 into Zapnspark's Schoeps generic electret front:
12k || 5k6 (piggyback) = 3k8 results in ~6db reduction
12k || 5k6 || 5k6 = 2k3 results in ~9db reduction
12k || 1k8 = 1k6 results in ~12db reduction
12k || 1k8 || 1k8 = 840R results in ~14db reduction and 2db headroom on soundcard input (clipped at capsule or mic preamp)
WM61 handles higher SPL, but with more than 20db of input gain, mic preamp/capsule noise starts to be noticable on peak meters, so I'll try to match that with -20db reduction (more than that would probably degrade S/N ratio). If these resistors are bridged, will preamp operate normaly (or, how low can I go)?
PS. I got +10db number (in my first post) by comparing Spirit with my SSM2019 based mic pre at unity gain. If that comparison was correct, that would mean that when R17/18 are lower than 2k3, preamp actually trims the signal?
I need a bit more help, please.
This mod introduced some sort of oscilation that looks like shifting resonant peak. When the desk is turned on, the resonance slowly moves up/down the whole audible frequency range (on modded channels only). As time passes, it seems that the shifting speed slows down, and that frequency span becomes more narrow, eventualy stabilising across very narrow band after a few hours. Peak amplitude is about the same on all the affected channels, but the peak frequencies are not the same/correlated. I used 1% resistors. This is with no microphone connected. When mic is connected, more resonant sweeps appear (some with wider q), and the sweeps are faster.
If it's too complicated to reduce preamp gain, would a 10k pot between R34 and gnd, with wiper connected to send/tip, work ok for variable reduction before the soundcard input?
That old schematic link is not working now... The Cohen topology should be pretty stable. If you reduce the feedback resistors around the op amps too low that increases the open loop gain working with the Rs connected to the device collectors and op amp - input. Try reducing the value of those collector resistors a commensurate amount to the reduction in the op amp feedback resistors.
I have never seen this instability before, nominally in the Cohen topology the collector load resistance is similar to the feedback resistance for a unity feedback factor. Making the feedback resistors smaller than the collector load effectively introduces voltage gain into the feedback path.
Of course there may be other remedies but that is where I would look first.
Regarding the above schematic (that must not be reproduced or disclosed), the 12k feedback resistors and 5.1k collector resistors nominally attenuate the open loop gain more than 6 dB helping stability. BUT the 22 pF capacitors across the 12k feedback resistors are actually adding some HF boost to that open loop gain. This may actually be working against stability (for stability we want the open loop gain to drop below unity gain by the time that the phase shift caused by internal time delay reaches 180' making negative feedback positive).
See if removing the 22pF caps improves the stability.
Thank you all for your replies.
@k brown
As JR says - SNR, but I'm basing this on few assumptions which may be wrong:
- mics to be used on these channels are "noisy" (specifically wm55 & wm61) and can only use resistive pads between mic and mixer (which probably also brings down mic noise together with the signal)
- 20db resistive pad that has "correct" impedances may require too much gain compensation, and spirit becomes noisy on higher gains (I noticed that with ribbon microphones)
- 6db & 10db resistive pads do not have "correct" impedaces and may "color" the sound (actually, if they do, I havent noticed that with those capsules - or did not care at that moment)
So, i thught that the "simplest" and most versatile solution would be to shift the gain range on few channels from 15-60db to let's say ~0-40db.
Spirit's "clean" gain (noise does not raise above the soundcard's noise flor) is about 15db (probably total ~30db over unity), so resistive pads would probably be OK if not for impedance missmatch (I'd love to learn more about that in context of transformerless mic/preamp) and resistors' thermal noise (if this is even an issue in this case).
@JR
I will try that, and if doesn't solve the problem or it changes the sound in some way that doesn't sound right to me, I'll give up - it's just that it takes too much time to experiment or potentionaly introduce a problem that I'll become aware of in the middle of some other thing. But thank you very much for taking your time and looking into it, I appreciate it.
The thing that bothered me was clipping the soundcard input (connected via mixer insert point) - I should've started the topic with that piece of information. It seems that mixer has more headroom/different operational level than the soundcard (+4/-10 thing?) - the insert sends can clip the soundcard input while mic preamp is not clipping yet, so some attenuation will be required even after the mic preamp gain reduction. If mic pre can take hot signal and that same signal output clips the soundcard, then output needs to be padded, which also reduces the noise perceived by soundcard (if it's above soundcard's noise floor).
I've tested two things...
Increasing resistance between the emiters (extra 10k brings down gain by ~6db, and it seems that it does not change the sound). I can put this resistor on a switch on a few channels (eg. on/off/on for 6/0/12db).
I've put a 10k pot before insert send point (as voltage divider), and it seems to work ok without "coloring" the sound. What suprised me is that when ground is disconnected from the pot, leaving 10k in series, the volume drops by ~6db - is that series resistance making a voltage divider with soundcard's input impedance?
I still need to test how much padding is required between the mic pre with full scale mic signal and soundcard's input, and figure out if it would be reasonable to pad all the channels (eg. if spirit's "clean" gain can compensate for this padding without introducing noise).
FWIW, back when I was DIYing mics with Panasonic capsules, I powered them with a 'battery box' that had unbalanced outputs for use with portable cassette and later poratble DAT machines. I went to a July 4th fireworks show and found myself right next to the mortars. The sound was so loud that no setting of the rec level was unclipped, so I reconnected them to the recorder's line input and got a perfectly clean recording. Proof that the capsules themselves can take enormous SPLs.
If you have a way of powering the Pannys that doesn't require phantom power, try connecting them to the mixer's line inputs.
