Hi.
I'm thinking about certain idea, and would like to ask you if you think it is ok.
My mixer has 16 channels, and I'm changing things inside, biasing to class A, and line channels will be added, so I will need stronger power supply. Instead of using one single external 5-amps power supply, I'm thinking of putting externally just big toroid, strong graetz and big capacitors and 5A fuses, and then put regulator sets (7818, 7918) inside the mixer.
Now, I'm thinking to split power load between several regulators sets, each feeding just few channels. Say, instead of one strong supply regulator set supplying all channels, including summing buss, I would make separate regulator sets for channels in groups of 4, and also use sepatare regulator set (with 24V voltage) on summing buss, and separate regulator set for headphone power outputs. Thus power consumption would be spread over several regulators, and I could get away with miminum sized heatsinks on regulators, and smaller capacitors.
Is this idea to have several regulator sets (possibly with different voltages) possible at all? Can there be any problems expected? What do you think?
thnx
thnx
