Hi, I was reading somewhere about impedance and how it can change the quality of sound and I was wondering if using a Y cable, to split the output of a DA converter to two different devices affect the sound quality? From my understanding, if both devices being fed is +4 line input, the sound quality should be the-same?
So if I was to split the output of a DA converter to a speaker amplifier with +4 line input and a Monitor Controller with +4 line input, both devices will receive the-same sound quality signal regardless, even if both devices uses gain/trim adjustments? Only if one device has -10 line input, or if I use a mic input will there be a shift in the sound quality.
Is this correct?
Thank you.
Is this correct?
Thank you.
