Check continuity of the ground pin with the case; sometimes the ground pin is connected to an internal electroastaic screen only.aviel said:Case is not but the screen pin is. I can try to ground the case also.
It's in the datasheet...Regarding the That 1646, i didn't actually know that.
You may not notice a problem, because it just ruins the CMRR, which is not immediately noticeable if you have a relatively clean environment. Even with a 5k pot, CMRR would be just about 20dB.What are my options in that case? I could use a lower pot, 5k for example..
If you want the 1646 to work as it should, you should precede it with a buffer.
