SSL 4000 EQ
Deejsirois said:
Thanks Vac 11! It gets crazy pixelated when I zoom in, but it's better than nothing ;)
EDIT: Got it working!! Woohoo! Sounds good out of the gate. Now to calibrate it properly
Great to hear you fix it! Where was the problem?
Whoops said:
I've also uploaded the original SSL EQ and Filters schematics to the technical docs section:
https://groupdiy.com/index.php?topic=45604.0
You're awesome! Thanks!
Whoops said:
Also the board layout
Super helpful!
It looks like now one can get center tapped pots from Aliexpress for cheap however they are mostly 50k and 100k ones (with detents as well). The dual gang 50k pot can be paralleled and used as a 25k pot.
Would anyone advise what changes in the schematic will need to be made (if at all) if I wanted to use single 50k CT pots?
As discussed somewhere in the first 2 pages a center tapped pot is not needed, you can add a toggle switch to bypass the filter if you want absolute "0" at center position.
Yes, I went through the thread couple of times but since those pots are not a problem to get anymore why not use them.
They are working perfectly, top quality, for sure with center ....
€ 3,14 | 2 TEILE/LOS Importiert TOCOS typ RK09 präzisions-potentiometer, doppel B20K gürtel, mittelpunkt schaftlänge, 20 MM langen faden
https://a.aliexpress.com/_msgO5d0
Hello guys!
Could you help me where I can get some nuts to these 6mm shaft potentiometers? I have a few from an earlier project so I meassured one but can not find any place on the web... 10mm diameter nut with 6,3mm hole.
Thanks in advance!
Hi everyone,
wow time runs by... my first post in this thread was 2012-10!! o_O
Since then the PCBs were laying around... waiting...
Last year I though that would be a quick, nice and funny project... but it turned out an other way... but that's an other story...
Currently I got stuck trouble-shooting... 😫
One channel is working fine, the second one has a problem in the LMF section.
I did all the easy checks: A/B comparing components, swapping NE5534, A/B oscilloscope comparing, re-soldered all components (both sides), tripple checked the P6 pot...
- No success... f*** 😫😭
Taking U11 out, the rest of the unit is working fine.
The Q-Pot P6 changes volume, creates artificial noise.
Has anybody a idea where to look next? What to check? Any ideas?
- Thanks!! 🙏🤟
... i'm lost...
Cheers!
Finished a "Quad" 2U 19" the last days... Super EQs, real workhorses..., Now I am owner of 6 Modules .... Thanks to Casey Pitman for this great PCB Design, Frank from frontpanels.de, and Vami Milan "Vac11" for the PCBs....👌 Cheers
    195.3 KB
    214.8 KB
    167.3 KB
    108.1 KB
    174.1 KB
    296.7 KB
    189.3 KB
    188.3 KB
    119.9 KB
    144.5 KB
Really wanna make this one to!! Look amazing!
