It was C68 and C64 on both channelsricardo said:Which were the capacitors you changed?
I can now turn the gain up 3/4 (3 o'clock) without noise (the vlz mixer being the noise-floor of -85db).ricardo said:Can you connect the +ve inputs (p3) of IC23 & 30 together? This disables the earlier stages. If the noise goes away whatever the setting of the GAIN, it means problem is in the earlier stages.
Is this the same on the good channel?G-Sun said:I can now turn the gain up 3/4 (3 o'clock) without noise (the vlz mixer being the noise-floor of -85db).
Then up to max gain, the noise peaks at -35db
I hope you mean C68 & C84It was C68 and C64 on both channels
I'll solder a short and checkricardo said:Is this the same on the good channel?G-Sun said:I can now turn the gain up 3/4 (3 o'clock) without noise (the vlz mixer being the noise-floor of -85db).
Sorry, typo, yes C68 and C84I hope you mean C68 & C84It was C68 and C64 on both channels
Thanks! Cool, didn't know about the servo-design. It makes sense.DC conditions tell us if a stage is working properly. U32b is a servo that's supposed to keep the outputs of IC30 & IC23 the same regardless of GAIN setting. I'm still trying to figure out why they are different.
Ch2: approx the same. Max gain, noise peak at -44db (reseted meters)G-Sun said:I can now turn the gain up 3/4 (3 o'clock) without noise (the vlz mixer being the noise-floor of -85db).ricardo said:Can you connect the +ve inputs (p3) of IC23 & 30 together? This disables the earlier stages. If the noise goes away whatever the setting of the GAIN, it means problem is in the earlier stages.
If the noise is the same on both channels on this test, the fault is at an earlier point.G-Sun said:Ch2: approx the same. Max gain, noise peak at -44db (reseted meters)ricardo said:Can you connect the +ve inputs (p3) of IC23 & 30 together? This disables the earlier stages. If the noise goes away whatever the setting of the GAIN, it means problem is in the earlier stages.
Ok,ricardo said:If the noise is the same on both channels on this test, the fault is at an earlier point.
Do you have P48V phantom power?
Works with a condenser? and +48V?EmptyMusicBox1 said:Hi everyone !
i have just finish my 9K SSl preamp and i have a problem ...
The preamp Working good with a LINE source and a Static MIC
But not working with a SM57 ....
i have a Go betwin interface how do you have Wire ?
thanks
I'm not sure I contributed anything except perhaps some idea of how to break the circuit into parts to check each one in turn. This indeed sounds like soldering.G-Sun said:Both channels are now working fine. Must have been something about the soldering around c68/c84.
Thanks Ricardo for all your excellent help!
ricardo said:I have to say, this close look at SSL9k doesn't inspire confidence. It is MUCH more complex than it needs to be .. hence difficult to troubleshoot.
Well, I don't think I would have proceeded with any trouble-shooting if it wasn't for your help.ricardo said:I'm not sure I contributed anything except perhaps some idea of how to break the circuit into parts to check each one in turn. This indeed sounds like soldering.
Another possibility is the 2 pots. .. both on the input stage and also on the 2nd stage. Something to bear in mind in future.
On your next project, once its working, measure voltages at important points (eg outputs of all OPAs) and note them on your schematic for reference.
____________
SSLtech & Rochey have a far better and simpler product in their new Eden boards based on TI INA163
