EmptyMusicBox1 said:Hi everyone !
i have just finish my 9K SSl preamp and i have a problem ...
The preamp Working good with a LINE source and a Static MIC
But not working with a SM57 ....
i have a Go betwin interface how do you have Wire ?
thanks
EmptyMusicBox1 said:But not working with a SM57 ....
Dual 2k2 rev.log is correct (and the max.gain limiting resistors are needed). The min.gain raises from +10dB with dual 2k5 rheostats to +11dB from your dual 2k2 rheostats on paper (the omeg pots come with +/-20% tolerance of rated resistance). I would use shielded mic cable between each deck and pcb, cable shield one side connected to a low impedance source instead of your unshielded, long, single, untwisted wires. YMMV.EmptyMusicBox1 said:for my SSl 9k i use a : Omeg 2K2 Log C with a Resistance 27R and 39R it's correct ?
chefducuisine said:Glad you sorted it out with Ricardo's help.
Enjoy the pre... it is really usefull!!!
Mine was used 2 weeks ago for drum recordings - came out excellent and easy to mix.
s2udio said:EmptyMusicBox1 said:Hi everyone !
What do you mean by " Static MIC" ?
They work fine with SM57's...........?
In fact any Dynamic Mic and any condenser as long as your providing the 48v.
And the dual gang rev log 2.2k is all that is required......maybe a 1db loss over a 2.5k pot.
The added resistors are not really required.
Edit missed the dec point !
Thx harpo
Harpo said:Dual 2k2 rev.log is correct (and the max.gain limiting resistors are needed). The min.gain raises from +10dB with dual 2k5 rheostats to +11dB from your dual 2k2 rheostats on paper (the omeg pots come with +/-20% tolerance of rated resistance). I would use shielded mic cable between each deck and pcb, cable shield one side connected to a low impedance source instead of your unshielded, long, single, untwisted wires. YMMV.EmptyMusicBox1 said:for my SSl 9k i use a : Omeg 2K2 Log C with a Resistance 27R and 39R it's correct ?
chefducuisine said:darkcharly,
I have added two Zip files containing 3 bar samples from BD, SD and OH to my SSL9k gallery.
Be shure to download both files and check the read-me file.
http://twin-x.com/groupdiy/thumbnails.php?album=510
What kind of psu are you using?darkcharly said:Hey!
My psu measure correctly -18v and 48v.
+18v rail reads 9v.
I changed the LM7818 (another brand) and now shown +14 volt.
I have to switch brands until I find the correct measurement?
any ideas?
Thank you!
G-Sun said:What kind of psu are you using?darkcharly said:Hey!
+18v rail reads 9v.
any ideas?
Thank you!
Disclaimer: I'm not an expertdarkcharly said:i´m using keith´s power supply!
On 18volt rails:
20+20 transformer
7818cv, 7918c
2x 1000uF, 4x 100nF Caps
and Bridge Rectifier W10M (1.5A 1000v)
Maybe the Rectifier should be smaller? :-\
Thank you!
G-Sun said:Disclaimer: I'm not an expertdarkcharly said:i´m using keith´s power supply!
On 18volt rails:
20+20 transformer
7818cv, 7918c
Thank you!
If you negative rail is outputting -18V, are everything mirrored on the positive?
In that case, check soldering or for faulty components.
Compare every voltage with negative rail.
Hey!chefducuisine said:Did you check for proper grounding - I never had any radio interference on this Pre. Even when used without any housing.
Other than that did you check if you installed all the required bridges? If you are using my layout please check Reply #585 - the bridges are marked in red colour.
It would be helpfull if you can trace the signal to know which stages of the pre are working properly. Are you able to do this? The easiest way would be to use your soundcard together with RMAA.
Is the voltage for the IC right? Checked soldering?darkcharly said:Hello!
Following the advice of chefducuisine, I tried the circuit 9k inserting an audio signal, and testing the circuit with an audio probe (listening to the audio signal through the circuit). The signal stops at pins 1 and 6 of the LM394 (Collector of each transistor). The LM394 is malfunctioning?
Thank you!
