[quote author="Ian MacGregor"]Anyone know of a way to do this with CorelDraw?Ian[/quote]
Hi Ian.
I'd done my calrec panel with hpgl. But it wasn't cheap. Okay the number of engraved objects is maybe 400% more or so.
There is a tutorial how to create hpgl scales in corel... it's only in german language... Michael Krusch translated the text
look here:
http://www.nrgrecording.de/html/schaeffer.html
(bottom of the page)
But i've got problems with corel. Don't know whats wrong. Maybe iam stupid or the program has an error.
You have to make a second contour to the inside (because the drill is bigger... so the line where the drill moves along has to be a bit to the inside of the engraving, otherwise the engraving will be bigger)
The distance is the half of the drill width. (if you have a 0,2mm drill so it is 0,1mm)
http://www.nrgrecording.de/assets/images/HPGL2.jpg
Then you have to remove the outer line (break apart...)
http://www.nrgrecording.de/assets/images/HPGL3.jpg
If the engraving should be filled you have to add more lines where the drill has to drive along. (contour to the inside) distance: 0,7mm (look at the chart of schaeffer)
After import to frontpanelexpress the filled areas should look filled. If the engraving looks okay and is filled out completely when full zooming. (what you see is what you get)
http://www.nrgrecording.de/assets/images/HPGL5.jpg
___________________________________________________________
The problems: :evil:
Sometimes corel do strange fillings and i don't know why :?:
http://www.nrgrecording.de/assets/images/HPGL6.jpg
The strange thing is... if i'll fill the letters some parts are NOT filled.
I point out that the filling works from the middle of the screen area to the top.. but don't work from the middle to the upper are...
http://www.nrgrecording.de/assets/images/corel_problem.jpg
I have to check this with other corel versions.
If someone has a tip about that... would be nice to know. I would like to do a tutorial with pics... so anyone could benefit of the informations. :wink:
