Thanks for looking over that Abbey ,
I needed to bounce out what was going round my head just to be sure I was on the right track.
I can see when I calculate the reactances at different frequencies for the choke it will make almost no difference at low frequencies and gradually has more effect as frequency rises .
I can see it would make a difference to the feedback depending on if the choke or resistor is closest to anode , but which scheme is better or the merits of either I dont fully understand . In this instance where a simple single coil choke is being used I can see how having the resistor onto the the anode might insulate it from capacitance and because the feedback path is resistive keep that more linear also, if the choke comes first it is encompased directly within the feeback loop etc
I suppose I should try and test it ,but Im not really sure what to test for , I can see triode, UL and pentode (resistive or regulated bias) are possibilities with or without additional choke loading ,but what I cant decide is what would be a meaningfull way of measuring or comparing the performance differences other than listening tests with actual musical content.
