L´Andratté
Wow, that´s called *Epic Fail*
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
PRR said:> AUX send level control R443 and
This gives a semi-Audio taper with a cheap linear pot.
I would say it's an "S" curve, a somewhat linear middle portion with log and antilog-ish ends, similar to those used in well-designed "swinging-input" graphic equalizers, allowing a large-ish value that gives a low noise gain, but permits smooth end-of-travel control.ruffrecords said:PRR said:> AUX send level control R443 and
On the schematic is says 50KG - does that mean LIN??
I used "S" taper back in my old kit company in the '70s so I could use the same pots for Baxandall EQ (flat at 50%) as volume controls, but i was cheap.abbey road d enfer said:I would say it's an "S" curve, a somewhat linear middle portion with log and antilog-ish ends, similar to those used in well-designed "swinging-input" graphic equalizers, allowing a large-ish value that gives a low noise gain, but permits smooth end-of-travel control.ruffrecords said:PRR said:> AUX send level control R443 and
In graphic EQ's, where 30 or 31 faders end up paralleled, that's very important, because the noise gain is directly related to the number of faders.
When designating letters for tapers, they probably should have skipped "G".ruffrecords said:On the schematic is says 50KG - does that mean LIN??
No one 's gonna blame you for that; "cheap" is a quality for a designer.JohnRoberts said:I used "S" taper back in my old kit company in the '70s so I could use the same pots for Baxandall EQ (flat at 50%) as volume controls, but i was cheap.
