eriksunding said:No DOAs. Just the four 5534s. But I accidentally hooked 16v to the DOA hole in the middle.
In that case, test the voltages on the circuit without the ICs inserted...
Gustav
eriksunding said:Anyone? Please..
The low filter peaks at low frequencies, nominally 20 Hz.eriksunding said:Bass filter: if I send a 10khz sinewave in to the eq I can boost or the signal a couple of db which seems weird.
The high filter peaks at high frequencies, nominally 20 kHz.eriksunding said:High filter: same as bass filter but the other way around. I can boost or cut a 20hz sine wave a couple of db.
The mid filter peaks at 150 Hz - 7 kHz, depending on the frequency knob setting.eriksunding said:Mid filter: Barley boosting when set to 150hz but the higher frequencies I choose the more I can boost.
Maybe it works just fine.eriksunding said:I've even had a really experienced tech look at it and he can't figure it out. He said all the voltages are looking ok and signal is passing through.
eriksunding said:So I replaced the faulty valued resistors and it now works and sound amazing!! (Surprise... :)
Thanks Audiox and Gustav for a great eq!
Over and out.
