corgan4321
Hello!
I'm working on a Studer 962 that sounds very nice. I was combing through the schematics and discovered the 961/962 channels strips have a vestigial unbalanced tape return input from the console's big brother the 963. It appears that by adding just a few components, the "off" position selects a tape input path. This "modification" is labeled as "Option 1" on the schematics so presumably you could order strips from the factory this way. I'd like to explore adding this function to at least 8 of my channel strips for my 8 track r2r returns. I've highlighted the areas in question on the schematic below. My questions are, how matched should JFETS be in this situation? I have a Peak Atlas Pro that can read Vgs and Idss easily but only at 5V. To what degree should the JFETs be matched in this circuit? For this type of circuit, is it important for the FETs so be tested in a similar circuit with similar sized resistors/voltages??
Also, it looks like to me that D18 on the bottom right of the page, and everything past Q13 is for signaling and to light a "Mixdown" LED that exists on the 963 when you have this tape return path selected. Is this a correct assessment?
The most difficult part will be to find a place for the input to go physically. There are two banana jacks that go unused (broadcast signaling jacks), so perhaps they could be removed and replaced with some more Bantam jacks.
