Hansblooey Ribbon
Active member
- Joined
- Apr 26, 2023
- Messages
- 38
Optivisor.
I have a pair of these too, but mine has a built-in lithium battery, so not heavy, Okay for what I need, but wouldn't want to wear them all day.Out of curiosity, I bought a cheap pair of LED magnifying glasses at Lidl for €10 this morning.
The whole thing is a bit plasticky and rather fragile.
The magnification is interchangeable from 1x to 3.5x, it could be a bit more but it's good for soldering and things like that. The LED is bright but unfortunately the whole apparatus gets quite heavy due to the 3x AAA batteries.
Conclusion: cheap, useful, let's see how long it lasts. In my opinion, such glasses are generally more suitable than magnifying lamps for soldering, see member @MicMaven post.
View attachment 138939View attachment 138940
The same here. If the workplace is brightly lit enough, the batteries can be omitted. This makes the glasses much lighter...Okay for what I need, but wouldn't want to wear them all day.
Yes, that is also a solution. But I always have problems with camera systems because the hand-eye coordination requires some rethinking. It's easier with glasses. Btw, with the Parkside glasses with the 3.5x lens the focal plane is about 23cm in front of the eyes. You are quite close with your nose, that's true.I recently did a mod on a AKG p220 which uses SMDs and as most would know there not the easiest components to work on.
I tried a couple of head mounted magnifiers but they didn't work as you had to be very close to see anything and the thought of having a hot soldering iron a couple of centimeters away from the tip of my nose was bit scary.
So I returned them.
I ended up getting a goose-neck phone holder which clamped to my bench and I used the camera zoom on my phone.
Works great and I didn't end up melting the end of my nose.
I have long ago ditched the boom-arm magnifier and use a headworn magnifier with LED lamp. I got mine from a market that sells all sorts of stuff from China and Indonesia. The lens carrier can carry 1 or 2 lenses and if using a single lens the lens can flip out forward for normal vision.SERVING SUGGESTION 193874 -- Use a head-worn magnification visor like jewelers do.
I HATE using a magnification lamp for multiple reasons.
1) The boom arm gets in the way.
2) The lamp is either too bright or too dim and may glare on the object.
3) The magnification is often too weak for the task or object
4) The boom and lamp constantly consume valuable air space over my desk
5) Expensive
6) Did I mention, it is always int he way over the desk?
The photos depict my alternative - whether they provide mor or less magnification depends on the model. I prefer the first one with white frame - they all work over eye glasses, too. While they may have LED lamps, I prefer other lighting over the desk for that.
Just MY take. Your mileage may vary. / James
View attachment 138921View attachment 138922View attachment 138923View attachment 138924
There are VR 3D headsets available that use an iPhone or Android phone as the viewer - you drop the iPhone into the internal holder - with the right adaptation of cameras and wifi transmitter mounted on the headset they could possibly be a way to make a totally electronic magnifying headset.My job as a lathe operator has forced me, for several years, to use different devices depending on the work I am doing. Reading measuring instruments, calipers, comparators, micrometers, becomes increasingly difficult with age. Therefore, apart from reading glasses, I use visor-type magnifying glasses with light on certain occasions. They are very comfortable, but like any magnifying lens, they only focus at a shorter distance the higher the diopters they have. This makes them unsuitable for certain jobs that involve welding. If you have young eyes, you could ask your eyes to compensate for a certain lack of focus. But the hardness of my corneas is measured in Rockwell degrees, so that is impractical in my case.
I have been using cameras with monitors for my electronics hobby for a long time. I don't think there is a better solution. A good USB camera module with a zoom lens and an articulating arm can be purchased for well under $100. And who doesn't have a monitor, or a PC, or a laptop that they can use in their workshop?
Not to mention an electron microscope, which costs a few hundred, and I really don't see any advantage over a zoom camera mounted on an articulated arm.
I love this forum. All the people are very kind and friendly. I send you my regards from Milei's Argentina, and I hope that Google Translate does its job. It's not that I don't know English. But my writing skills are more than limited in that language. Greetings.
no hablo espanol?Mi oficio de tornero me obligó, desde hace varios años, a usar distintos dispositivos en función del trabajo que esté realizando. La lectura de instrumentos de medición, calibres, comparadores, micrómetros, se torna cada vez más difícil con el avance de la edad. Por lo que, aparte de las lentes para leer, uso lupas tipo visera con luz en ciertas ocasiones. Son muy cómodas, pero como cualquier lente de aumento, sólo enfocan a una distancia menor cuanto más dioptrías tengan. Lo que las inhabilita para ciertos trabajos que impliquen soldadura. Si uno tiene ojos jóvenes, le podría encargar a sus ojos compensar cierto desenfoque. Pero la dureza de mis córneas se mide en grados Rockwell, por lo que eso es impracticable en mi caso.
Hace tiempo que uso cámaras con monitores para mi hobby de electrónica. No creo que haya una mejor solución. Un buen módulo de cámara USB con una lente zoom y un brazo articulado se pueden comprar por bastante menos de 100 dólares. Y quién no tiene un monitor, o una PC, o una computadora portátil que pueda usar en su taller.
Eso para no hablar de un microscopio para electrónica, que vale algunos cientos, y realmente no le veo ventajas sobre una cámara con zoom montada en un brazo articulado.
Me encanta este foro. Toda gente muy amable y simpática. Les mando un saludo desde la Argentina de Milei, y espero que el traductor de Google haga su trabajo. No es que no sepa inglés. Pero mis habilidades de redactar son más que limitadas en ese idioma. Saludos.
This is a google translation, provided by the forum:no hablo espanol?
Gracias....This is a google translation, provided by the forum:
There are VR 3D headsets available that use . . .
A fixed lens on a boom is OK if you are just touching up a couple of cold solder joints or adding a connector to a cable. It is quite another matter if you are building a full ham radio transceiver or linear RF amplifier with 450 through-hole and SMT parts, and you harbor unrealistic, groundlessly hopeful expectations it will actually work when finished.
