See Post #67 in this threadwhere we can find rhis pcbs
Hi MicUlli,Outstanding: frequency response S502 (1st version).
Find attached some pics...
Alas, the capsules are electret and soldered a way way (ring is conected to backplate and ground) that one can't test them in Schoepses, though they would fit. Electronics are very basic with a double opamp GS6002. They sound good and the "finish" is very nice Schoepsy.Bingo. That’s what I get for trying just once and being too frustrated with tiny tools to even think about trying the other way.
Hi Jan,Hi MicUlli,
Could you also share frequency response charts of both the mk1 and mk2 versions? Preferably at 0, 90 and 180 degrees, if you can. I could do them myself with the mics I have, but I do not fully trust the results
Jan
Great news thank you, I noticed that a fair amount of smd components are required. I've only done repair on a single smd component before. Is it reasonable to attempt building this or is it too big of a step for smd beginner ?Hi Jan,
the frequency response of the S502MKII under different incident angles was already posted in #56. It has not changed significantly with my electronics.
Find attached the frequency response of the S502 with my electronics. I purchased the S502 from "Kleinanzeigen" as "defekt". And it was, so i didnt try to repair the old electronics...
Very pleasing are the noise measurement results:
S502MKII self noise is 14,1 dBA (SPL) left channel and 14,3 dBA (SPL) right channel. Sensivity is -37,4 dBV left channel and -37,7 dBV right channel.
Overload point is around 138 dB (SPL).
S502 (1st version) self noise 15,6 dBA (SPL) left and 16,2 dBA (SPL) right. Sensivity is -43,4 dBV left and -43,7 dBV right. Overload point is around 144 dB (SPL).
No noise artefacts above 20kHz thanks to the very stable JFET-oscillator (420kHz)
Now shipping of the "repair kits" will start...
Best regards MicUlli
Well, it depends...Great news thank you, I noticed that a fair amount of smd components are required. I've only done repair on a single smd component before. Is it reasonable to attempt building this or is it too big of a step for smd beginner ?
Hi Ulli, I was interested in the boards as I wrote before, how can I order/pay them?Hi Jan,
You'll be fine.Thank you guys, I'll get a couple of boards in case I fumble the first one : )
then S502mk II is more silent but have less dinamic range because, I see S402 mor for drum s and S502MKII for calssical recordings, isn't it?Hi Jan,
Hmm, i am not sure. I doubt that you produce an SPL of more than 130 dB with your drums in practice...then S502mk II is more silent but have less dinamic range because, I see S402 mor for drum s and S502MKII for calssical recordings, isn't it?
I understand that i S502 we coul use an standar phantom the 39 limitation is doing inside the pcb?After calculating some technical and commercial aspects i am going to consider the design of pcbs for the Superlux S502MKII based on my MicUlli-design (MBC5X0), see https://groupdiy.com/threads/a-very-versatile-input-stage-for-sdc-mics.80172/
Requirements:
1. Board shall have the same size as the original
2. Using surface mount components, only electrolytic caps are discrete
3. Optional DCDC converter for -20V (will lead to 59V pol voltage and a higher sensivity)
4. Board shall also be usable for the S502 1st version (with the bigger capsules), but limited to 39V pol voltage
Advantages:
1. Better SNR (as already proven)
2. Better max. SPL (as already proven)
3. Much smaller THD
4. No spurious noise artefacts above the audible range
I need at least 2 boards, some of you want 4 boards (thanks for that), but it makes no sense to order components for a batch smaller than 15 units. So let me know (drop a PM) whether you are interested in some of these "S502MK1+MK2 repair kits"
So long MicUlli
High pol. voltage is indeed dependent of supply current drawn from P48 voltage. 39V is a compromise...I understand that i S502 we coul use an standar phantom the 39 limitation is doing inside the pcb?
Hi @Recording Engineer can you do please some comment on the sound of the mic in its original version ?Well I just now ordered pair… I want the bodies! Some M221b-inspired mics with Schoeps MK22 capsules might be fun! AMI T28 seems to be the only available option for these.
Video Plus (France) also sells an hypercardio mic (which should be interesting according to @k brown's taste for hyper ORTF)Another variant from E-Image:
https://www.eimagevideo.com/E_mobile/pro_detail/tid/93/id/1250
Available in Europe (at least in UK):
https://proav.co.uk/e-image-professional-broadcasting-microphone
.. and France (Product temporarily unavailable):
https://www.videoplusfrance.com/fr/5138212-e-image-professional-broadcasting-microphone.html
