Superlux S502 MK2 test, teardown and improvements
Maybe, “free field” means “plane wave field”, so, for example, very large distance in free field conditions. With an established manufacturer, I would hope for a standard measurement distance of 1 m of published graphs if nothing is explicitly stated (I think the Line Audio graphs are exemplary in this regard). Here is a quick simulation for a 22 mm cardioid at different distances (based on the formulas given in the Shure paper). I still don’t understand enough to say whether the chosen lumped parameters are realistic.distance-cardioid.png
For a figure 8 microphone, the effect is even more pronounced. See e.g. the quotes of Jörg Wuttke regarding the low-frequency response of a Schoeps MK8 and the lengths they go through in development to get the ‘real’ response.
Most helpful would be the following spec.
1. Free field condition (no reflections)
2. Plane wave (source is very far away) OR distance to source
3. Incident angle
With these data microphones could be compared easily...
Definitely let us know, I'd been eyeing those too, interested to hear how they are
let us know please when you receive the 92€ Ali SDC mic (Schoeps look) and how it sounds with the chineese original caps.
Well they arrived. Look and feel great! Their capsules and the Superlux S502 MKII capsules fit on each other’s respective body, but neither of them work (no sound) on each other’s body.
Just at home, I plugged them into my Big Knob and listened on my talking voice (very baritone). The CML-300 sounds pretty-damn good. Great cardioid-pattern and off-axis sounds really good! Very sensitive to plosives close-up, like the S502 MKII. If I had to guess, maybe a couple DB more noise than the S502 MKII and certainly much more proximity-effect!
Interesting. And thanks for sharing your findings. Did you figure out why the capsules did not work on the other body? Does the CML-300 have an electret capsule with JFET maybe?
Jan
Hum, they (Superlux & CML-300) seem to have exactly the same capsule's connexion... and I don't think the CML is an electret...
Can you provide please a pict of the PCBA ? and another one of "under" the interface connector ? (the white ring inserted in the mic body)
You could also measure if a voltage is present on this ring, capsule appart, when the mic is fed with 48v...
Regards
I make a perfect cardioid to have -27dB 1m 180 response at 1kHz. Otherwise, your shape is sorta correct.
"Diffuse Field" and "Free Field" are entirely about distance.
Not quite.
"Free field" is at a loo.oong distance such that the sound wave is planar. So "Free field" == "Plane Wave field".
"Loo.oong" is frequency dependent.
"Diffuse field" is about picking up the reverb field which (by definition) is independent of distance.
Isn’t that what is usually called “far field” (which should be distinguished from “free field”, as pointed out above by @k brown)? No reflections (free field) are still required for the measurement though.
My point was not to show a perfect cardioid simulation, but rather that a directional microphone’s low-frequency response depends on distance. In particular, an ORTF system positioned at, say, 2 or 3 m might have a higher -3 dB corner frequency than that shown in the published (on axis) frequency response (measured at 1 m).
Alright. There ya’ll go. The CML-300 is most definitely electret.
I have to get a different screwdriver to open it up. The only one that’s small enough is my smallest flathead in my cheap jewel set and the screws are so tight that’s it’s not allowing me enough torque. Even if I had enough grip, the screwdriver will just break.
In which direction did you try to turn the screws? Perhaps those tiny screws at the bottom end should be turned inwards, i.e. clockwise. That's how the screws on the S502 MK2 capsule interface must be rotated to remove the interface from the mic body. But maybe you already tried that...
Jan
Bingo. That’s what I get for trying just once and being too frustrated with tiny tools to even think about trying the other way.
    2.1 MB
    1.6 MB
    1.9 MB
    2.1 MB
    912.2 KB
So, @Recording Engineer , what have we got here : a (very ?) nice sounding SDC cardio with electret capsule and OPA as impedance converter... for ~100$ ???
Could you provide please some (even short) samples ? Voiceover and some acoustic instrument of your choice ?
Regards
News from the hardware front. Design is now tested for both the S502 and S5602 MKII version with satisfying results :)
Outstanding: frequency response S502 (1st version).
Find attached some pics...
    1.2 MB
    2.6 MB
    2.1 MB
    1.3 MB
    1.2 MB
    685 KB
    761.3 KB
    674 KB
    1.2 MB
