See Post #67 in this threadwhere we can find rhis pcbs
Hi MicUlli,Outstanding: frequency response S502 (1st version).
Find attached some pics...
Alas, the capsules are electret and soldered a way way (ring is conected to backplate and ground) that one can't test them in Schoepses, though they would fit. Electronics are very basic with a double opamp GS6002. They sound good and the "finish" is very nice Schoepsy.Bingo. That’s what I get for trying just once and being too frustrated with tiny tools to even think about trying the other way.
Hi Jan,Hi MicUlli,
Could you also share frequency response charts of both the mk1 and mk2 versions? Preferably at 0, 90 and 180 degrees, if you can. I could do them myself with the mics I have, but I do not fully trust the results
Jan
Great news thank you, I noticed that a fair amount of smd components are required. I've only done repair on a single smd component before. Is it reasonable to attempt building this or is it too big of a step for smd beginner ?Hi Jan,
the frequency response of the S502MKII under different incident angles was already posted in #56. It has not changed significantly with my electronics.
Find attached the frequency response of the S502 with my electronics. I purchased the S502 from "Kleinanzeigen" as "defekt". And it was, so i didnt try to repair the old electronics...
Very pleasing are the noise measurement results:
S502MKII self noise is 14,1 dBA (SPL) left channel and 14,3 dBA (SPL) right channel. Sensivity is -37,4 dBV left channel and -37,7 dBV right channel.
Overload point is around 138 dB (SPL).
S502 (1st version) self noise 15,6 dBA (SPL) left and 16,2 dBA (SPL) right. Sensivity is -43,4 dBV left and -43,7 dBV right. Overload point is around 144 dB (SPL).
No noise artefacts above 20kHz thanks to the very stable JFET-oscillator (420kHz)
Now shipping of the "repair kits" will start...
Best regards MicUlli
Well, it depends...Great news thank you, I noticed that a fair amount of smd components are required. I've only done repair on a single smd component before. Is it reasonable to attempt building this or is it too big of a step for smd beginner ?
Hi Ulli, I was interested in the boards as I wrote before, how can I order/pay them?Hi Jan,
You'll be fine.Thank you guys, I'll get a couple of boards in case I fumble the first one : )
