I measured both coils with an LCR meter, the rewound unit shows noticeably less inductance on all windings. I am admittedly not sure if I'm interpreting/measuring properly, but there is still a difference between the two coils. Is there a better way to be measuring the inductance here?
lassoharp said:I measured both coils with an LCR meter, the rewound unit shows noticeably less inductance on all windings. I am admittedly not sure if I'm interpreting/measuring properly, but there is still a difference between the two coils. Is there a better way to be measuring the inductance here?
Regardless of meter inaccuracies over 'true' L value I would think that your measurements still point to a valid difference. I mean, even if measuring with an inductance bridge gives a different number the relative values between the two should remain essentially the same should they not? Have you been able to measure response with the rewound iron yet?
The Edcor sucks - not sure what that's about.
