pinebox
- Joined
- Mar 11, 2015
- Messages
- 119
Im in the middle of modding a console supply by swapping out a 5v rail for an 18v to adapt to a different console than design intended. I was going to just drop in the same brick with different voltages, but the line of power bricks inside only has a 15v or 24v option. I dont know much about switching supplies, is there a way to swap the mosfet or such to swing the voltage closer to what I could use? The 15v can tweak up to 17.5 which I probably could get away with but I would prefer it a bit higher. Worse case I just use a different company and drop in a 18v brick, but I really like it when stuff stays clean looking and uniform, even if no one will ever see it.
