thor.zmt
That IRF610/9610 is THT
Nope, it's SMD, just find the right Suffix, DPAK2 IIRC.
and the article you posted is about using an LME49710 with bias current relief via the bootstrap for source impedances up to 1M, so I do wonder if you might not be veering towards a very flexible network to surround a paralleled LM4562 with 1M/220n or something. Y’know, breadboardable. Polypropylene in that case I suppose, though I am recalling one affordable PPS series with leads, maybe Kemet.
I personally strongly tend towards FET's over BJT, not always, but often.
The particular way I do Op-Amp's for AC is down to wanting to avoid coupling capacitors as much as possible.
As long as we use really low distortion Cap's (SMD C0G are usable) this circuit is invisible for AC, DC is reliably blocked without big value electrolytic cap's and lookback impedances for both inputs are always balanced (if we take care of this in the external circuit).
Typically I also have 10pF C0G in parallel with the resistors.
If paralleling multiple Op-Amp, use current sharing resistors and parallel the AC side (if needed with low value isolation resistors.
BTW, to get more output current Sandeman "Class S" aka Technics Class AA is a better choice IMNSHO that brainless paralleling. Even better with a minimally AB biased Class AB output stage on second Op-Amp.
Noise can always be dealt with using a secondary noise cancelling amplifier, which includes bipolar Op-Amp's.
It is possible to make really innovative "compound" op-amp's that are much more interesting than parallel inputs or outputs.
The 5534 is especially interesting because we have various commonly inaccessible nodes brought out.
We could use one 5534 to be the core of a FDA (using a second unit as inverter), using external 1nV|/Hz J-Fet's as input stage, with accessible sources (!!!) and use local feedback loops to the J-Fet drains as both virtual "folded cascode" and to lower overall gain back to stable conditions. Bring up second stage current while we are at it to improve slew rate and linearity.
The use Pin 5 on both 5534 to drive an external buffer, maybe diamond or Diamond Sziklai.
No monolithic Op-Amp or FDA exists that can match what this puppy can do...
Of course, at that point we are only a dozen or so parts away from fully discrete.
Thor
