Small update, since I got some missing parts yesterday.
Measured my AC supply today (40 across, 20V to each tap from center)
Connected it to the PSU without the 18+/18- jumpers connected to the circuit from the PSU. Got 18+/18- DC coming out.
Made the jumps (no smoke!). Output transformers mounted, ICs omitted. 18+ looks fine, 18- reads 9-.
Will cut the PSU and try it loaded to something I know is working, and if it is, I will check if I simply need to mount the ICs to get the -18 rail going. I had a similar problem with an earlier project, where the voltage was loaded down on diodes going to the ground rail/the output trafo mounted.
Not really in a rush - still trying to find a NOS dual FET, so I can shoot it out against candidates for replacement.
Does anyone know this shop? https://www.studioelectronics.biz/sunshop/index.php?l=product_detail&p=1176
Gustav
Gustav
