Potato Cakes
All righty, after putting this project on hold from touring all of last year, I am now able to start to work on getting this console fixed up and put to use. Since last time, I met with a circuit designer here in town to discuss making daughter cards to replace the bus EQ with a 553 circuit using the fancy ones from CAPI down to some smaller, economical options. It seems that I will have plenty of space to fit everything up to the height of a 2520 style op amp. I'm planning on leaving off the transformers as the signal in the console will already be unbalanced. Footprints for stepped and variable gain controls will be included. That might not get finished till after the recapping takes place.
I just went through the PSU and did all the updates in Colin's PSU Fix for the TO-3 sockets. Powered it up and it works great. I do need to find a fan. Does anyone who as done this have any recommendations? It doesn't need to be a quiet one as the PSU will be in another room.
Another thing I'm looking at doing is balanced inserts, however I will be doing this off board. JLM sells a handy PCB that will balance or unbalance signal with very good noise measurements. The only this is I would need 48 of them to handle balancing duties for all 24 channels. I'm looking at some options for DSUB break out PCBs to minimize the additional wiring needed in a rack case as it's all ready going to be quite a bit of soldering for all of the cables from the console, to the balancing units, to the gear and back. This is sometime I may abandon all together and just do inserts directly at the interface. It's just handy to have them directly at the console and not bother with additional software manipulation. Maybe I'll see about getting an all in one board made. Hoping later this week when I finish a mixing the current project I am on that I'll start removing channel strips and breaking in my new desoldering gun.
In the meantime I'm going to go over the information I have been massing for this project and make sure I'm forgetting anything, which I will regardless.
Excited to get back to this project and I'll update along the way.
Paul
Paul
