I like where this thread is going, fun stuff! I rebuilt my Scorpion II about three years ago... with mods still ongoing.
Start the whole process with a full PSU rebuild. The power supply rebuild really opened up the board. The board was really very tired, but a full recap did wonders. AML carries the five-pin caps which made direct replacement easy. I ended up adding a bit more capacitance and adding bypass caps, but that was all well after the basic rebuild was done. I changed out the fuse holders (as did Jens) as they were an obvious weak point. Added a fan and a switch. The fan makes a huge (HUGE) difference in the cooling of the PSU and is a must-do, not at all optional. I also raised the heat sinks up off of the PCB. Some of the transistor mounts were broken, cracked in half... so some modifications were needed to arrive at a more durable, fail-proof design. I can confidently say that there is nothing wrong design-wise with the AMEK-TAC PSU. I am running 24 channels, 16 busses and the master buss. All is well. Clean, quiet and humming along nicely. Nowhere near the load capacity of the supply.
Without doing the PSU first it is really impossible to make any judgement about the mods you might do. I went down this rabbit hole the other way and it was a mistake.
I put in 24 of the Langley mic mods, and 8 of the Langley line mods. They are good mods, well documented and incredibly easy. They sound excellent. At less than $40 US per channel they are way far on the favorable end of the price to performance ratio. Know that they come with all the caps needed to recap the whole channel, as well as the pots needed for the mod. I am very happy with where it has gotten this board to.
I used a modded Symetrix 202 a lot back in the late 90s and that mod is a pretty smart idea for this console. I have some extra channels so maybe I'll chase after a few channels and make the changes. The Symetrix was a big jump up from the Mackies that were prolific during that time.
I spent a lot of time on the master buss. Every minute of that was well worth the effort. Removing caps, re-chipping, cap selection, better pots... Most of that stuff is easily searchable here and elsewhere.
I like the EQs on the console. I don't EQ a lot, but they do a great mid-range guitar crunch when called on. I haven't chased after any EQ changes yet, but it is the next obvious step.
On an editorial note, I have maybe $1300 into this console. In a world where $1300 in parts for a compressor build is hardly out of the ordinary, the TAC has been an incredible bargain. I can't imagine anyone will ever be able to see past the reputation of a TAC Scorpion to give me that amount of money for it. Quite likely they will be scared of the "mods" and that will cause even further difficulties in ever selling the console. But for $1300 I have a great console for my personal use, and lower budget pet projects, that does everything way better than I need it to at home. Its "weird" split console work-flow works for me. I like fiddling with it when I am not building other stuff. However, I also really like that it works... and that gives me time to work on better tube projects and make music. Frankly it suits its role well. All that said, we still bought a better "world-class" console for the studio for pennies on the dollar of what it was new.
