I think that´s not the right way.
Do you deny that using a 1:1 xfmr results in a noise factor that is about 20dB worse than with a 1:10?
An expensive one, though. All this iron... 1:18 input (unobtainium), power xfmr with 3 separate heaters, two parafeed chokes and one output.Well damn, that might be an approach....
They could, but it would imply increasing B+ significantly.Could the chokes in the V41 circuit be replaced by constant current sources?
