Testing Neumann without capsule
mitsos
Need to test some old KM's.. Neumann's old lit shows an MA adapter which fits in place of the capsule, which imitates the capsules capacitance, and allows you to inject a signal without the capsule. Since I don't have one of these adapters, can someone help me make a rig to do what they do?  Is it a matter of removing the capsule and strapping a capacitor in it's place?
tia!
Thanks for the confirmation.  So the capacitor connects to where the capsule normally goes and signal is injected post cap?  I think neumann has published capacitance specs, so use that value as a base?
Yes, you should approximate the capsule value as closely as you can.
Which KM series is it? The KM5x (and KM25x) have a calibration input already provided.
you could also build a box w/shielded connectors, put the mic (with it's body removed & dummy capsule in place) in the box and feed the test signal in. Then the box acts as the hum shield and you have room to play.
I built one years ago and it is indispensable.
40pF for small D, 80pF for large. use polystyrene or mica.
thanks guys.  david, that's a great idea!  A good shielding solution is the hardest part.
cheers!
