Thanks for the schematic.
It is impossible to predict what that cap will do without looking at the specific input circuit it is connected to. Further it will very likely act differently when connected to different destination inputs.
The fact that you report hearing a difference suggests there is signal current flowing back into or out of pin 3 from the destination termination. This voltage is subtracted by differential action at the destination.
I would be inclined to add a small R (50-100 ohm) between pin 2 and the THAT chip output line. Likewise a similar value R from pin 3 to ground.
If you wish to add a high pass filter to the signal perhaps locating it in series with the very inputs would give you the most predictable and stable results, but these would probably be electrolytic for typical cutoff values and perhaps not the most ideal capacitor dielectric.
A C in series with RG would likewise add a HPF pole in the gain function, but again would require a larger electrolytic value.
