davemascera
Active member
- Joined
- Mar 22, 2017
- Messages
- 43
DaveP said:Most of the old compressors were designed for radio transmission, so the timings were fixed (they were playing mastered recordings after all). For recording purposes, you need a selection of attack and release times. The normal way to do this is to keep the cap value constant but switch in various series resistors to feed it for attack, then a similar switch in parallel for release. The advantage of switches is that you can make a record of the settings for the track, not really possibly with just a pot.
0.1uF can allow a slight ripple which on some feedback compressors can turn into motorboating, 1uF is used on the Fairchild and others, but many other comps get by with 0.25 or 0.5uF. Resistors that add with each position are mainly used to avoid switching noises, changing caps will probably cause some sudden charging noise.
Hmmmm interesting... so if I'm understanding this, throwing in a 300k pot will probably make my attack around (if fully engaged) 33 ms, as opposed to a fastest-case (and apparently not plausible) 3ms. That's if the first time constant cap remains at .1 uF, which you're saying may create motor-boating, or rather does in some circuits.
It might be a good idea to omit the second time constant altogether. I get the feeling that this was also created with television advertisement broadcasts in mind.
So if I then threw a 2.5 Meg pot in front of an 800kohm resistor, that would supposedly range from about 80 ms to 330 ms on the release...
And all of this is ideal and likely won't really perfectly reflect the reality of the time constants.
Lots of experimenting to be done I suppose. I don't care for switches (though I'm already using one of those Chinese dual 24-step attenuators on the input). This will likely be used on vocals and I compress before it hits the tape.
