The Dolby Trick !
You just prize off the coloured lens cap and pull them out with some small nose pliers.
Make sure the power is off otherwise you can short out the supply when doing this.
The original switch lamps are 24v. T5.5 wedge.
Most people replace them with the LED retrofits.
cheers barclaycon  ;) i thought you could probably prize them off from the front...  i had a look at trying to get at them from the inside and it seemed way too involved for a simple lamp change.
Ok guy's got a pair of 361 dolbys/ cat22 Dolby A, which mod do you recommend? I going to feed them off a console aux or routing.. or that's the plan.
