Hi @analag! I wish you success!View attachment 143410
I'm going to give this China tranny a shot. I had to use an impedance tester to get the connections right. I expect good things. And sorry I never stuff PCBs strickly perf boarder here.
797 CY039 ?This one has a 797 Audio edge terminated capsule. Very sweet.
It may be a body that looks like it, but all my mics are DIY. If I build a mic and I'm not satisfied, I gut it and start again. I built ten mics, two of which were solid state on my last building spree. This time it's going to be only four. All the parts are here or on the way. The 797 CY039 is an excellent capsule, I made five mics with them and I didn't have to manipulate the curve. Just put them in a simple circuit that is properly designed and let em sing.Hi @analag! I wish you success!
The most challenging and beautiful part of DIY is experimentation. It gives me the greatest satisfaction.
* I think I saw an sct-800 there. Can you describe a bit what stock sounds like, and what mods you did?
I'm tempted to play with one.
(or is it a bm-800?)
Thank you!
Hi @analagIt may be a body that looks like it, but all my mics are DIY. If I build a mic and I'm not satisfied, I gut it and start again. I built ten mics, two of which were solid state on my last building spree. This time it's going to be only four. All the parts are here or on the way. The 797 CY039 is an excellent capsule, I made five mics with them and I didn't have to manipulate the curve. Just put them in a simple circuit that is properly designed and let em sing.
I sent an email stating that I was starting a small microphone company and I needed samples. So they made them up. I had to wait for them to be made. A combination of center and edge terminated. Had to do a wire transfer and all that. They all sound fantastic. None of that frizzy top end. I run them all in flat circuits and most times I don't need a deesser on vox. Center terminated is warmer and sits in the track, edge terminated is more up front, articulate and raw. Two very usable sound. The other day I made a mic with a cheap eBay dual sided K47 and a transformer I ripped out of my old TCM1050, it sounds gorgeous but noisy as hell. So that one is getting a revamp while I'm doing these four. After that an all pentode mic pre and that may be the end of my 49yr DIY career.Hi @analag
really valuable information, i like edge terminated capsules too
How do you get the 797 capsules?
Fascinating stuff!I sent an email stating that I was starting a small microphone company and I needed samples. So they made them up. I had to wait for them to be made. A combination of center and edge terminated. Had to do a wire transfer and all that. They all sound fantastic. None of that frizzy top end. I run them all in flat circuits and most times I don't need a deesser on vox. Center terminated is warmer and sits in the track, edge terminated is more up front, articulate and raw. Two very usable sound. The other day I made a mic with a cheap eBay dual sided K47 and a transformer I ripped out of my old TCM1050, it sounds gorgeous but noisy as hell. So that one is getting a revamp while I'm doing these four. After that an all pentode mic pre and that may be the end of my 49yr DIY career.
