Hey,
I got a little problem with my G9. One channel doesn't work at all, no signal comming out. No matter what Input is selected.
It worked before, but after some fiddling around and changing transformers, it doesn't work anymore.
I undid the changes, swapped transformers, changed XLR's, changed output cap, switched tubes, still no signal...
Channel 2 works fine. I also measured voltages and compared, and to the last resistor R30/R130 all voltages are almost the same...
The weird thing is, sometimes, but very seldom it still worked for short time.
Does anybody know, where I should look at or what the problem could be?
UPDATE: swapped relays, now I got very, very little signal but only when in MIC mode.
So signal seems to come through, but really low, thin and distorded.
Any clues?
