shabtek said:@A-Ape do you have ps loaded with rest of circuit; you should have some kind of load or voltage may be high\regulators may fail\to regulate
No, no load. I checked with the schematics and saw that at C15 I should have 245V, so that's where my build stops.
ln76d said:If you measuring PSU only without the rest of the circuit, then it should be correct. WIth the load (tubes) voltage should drop.
Ok, cool thanks! I already thought so but wasn't sure as 30V difference seemed a lot for me.
