andow said:I recently tried running mixdowns through the line input of my G9 and really liked what it does to my mixes. One thing that bothers me however is the lack of low end. I know that it wouldn't be perfectly flat down to 20Hz, especially after reading this thread:
https://groupdiy.com/index.php?topic=9813.0
But just for reference I measured the frequency response and accidentally discovered something strange: the lower cut off frequency rises if the unit is on for some time!
In the attached image you can see measurements I made over a period of three hours, the corner frequency has gone up one octave!
Any idea what might be causing this?
Ok, new insights!
I changed the output tubes, swapped the input tubes, the effect is still the same on both channels so it has nothing to do with the tubes themselves.
I opened the unit to measure voltages, everything worked fine as long as the lid is off. As soon as the unit was closed and in the rack again the cutoff frequency started to rise, so I suspected it has something to do with heat. When putting a fan behind the rack the cutoff frequency slowly dropped again, so it's definitely one of the regulators getting too hot.
I can't measure voltages with the G9 closed in the rack but I guess it's the 78S12. The heatsink already is pretty big, but maybe it has to be even bigger...
Is this some kind of behaviour one would expect when the heater voltage regulator is getting too hot? ???
